How do I generate temporary one-time passwords for LastPass?
You can generate a list of one-time passwords (OTPs) so they can be used whenever needed.
You have successfully generated as many one-time passwords as desired.
Tip: You can click Print and store your list of one-time passwords in a safe place, crossing them off as you use them. Alternatively, you can click Print and save as a text file that you can update as you generate new one-time passwords.
