The new import experience takes place on the same browser tab of your LastPass vault.
Before you begin: Export your vault data from
LastPass (see instructions
here and
here).
- Log in to LastPass and access the Import page by doing either of the following:
Login method |
Instructions |
LastPass browser extension (new experience) |
The import feature is only accessible from within your online web vault. See instructions for LastPass website below. |
LastPass browser extension (previous experience) |
- Select
in your web browser toolbar, then enter your email address and master password and select Log In.
- Select
then go to .
LastPass website (online web vault) |
- Go to https://lastpass.com/?ac=1 and enter your email address and master password, then click Log In.
Your vault displays the Step 1/3. Where are your passwords now? page.
- Select LastPass.
Step 2/3. Export & upload page.
- Under Upload the exported file to LastPass, choose from the following:
- Drag and drop the CSV file exported from LastPass.
- Select browse your computer. Browse for the LastPass CSV file on your computer, select it and click Open.
Your vault displays the items found in the
LastPass CSV file.
Troubleshooting: If incomplete items are detected (entries are missing a username, password, and/or URL), select
next to the affected item (under the Data Status column), then enter the missing information and select Save.
- By default, all items are selected for import. If desired, make the following changes:
- De-select items you don't want to import.
- If you want to create duplicate items (by importing items with the same username, password, and URL that already exist in your vault), enable the Select all duplicates setting at the bottom of the list.
- Select Import All.
Results: Your exported
LastPass data is now imported into your
LastPass vault.
