How do I import a LastPass Encrypted file that was exported from LastPass?
You can import your LastPass vault data that you exported as a LastPass Encrypted file using the LastPass browser extension or directly from within your vault.
Important: In order to import LastPass vault data back in to LastPass, you will be required to enter the encryption key that you created during the export process.
Restriction: Importing directly into a shared folder is not supported. This means that all items will be imported as items within standard folders.
Import using the new experience
The new import experience takes place on the same browser tab of your LastPass vault.
Before you begin: You must export your vault data as a LastPass Encrypted file (view
these instructions).
Results: Your exported
LastPass Encrypted data is now imported into your
LastPass vault.
Import using the previous experience
The previous import experience opens in a new browser tab.
LastPass vault.
