How do I import passwords from 1Password into LastPass?
You can import your 1Password passwords (exported as a CSV only) into your LastPass vault.
Import using the web browser extension or from within the LastPass vault
Before you begin: Export your stored data from 1Password as a CSV file (
instructions here).
You have imported your stored passwords from 1Password into LastPass.
Autofilling after import
Once imported, you might notice that some websites do not autofill right away. This is because LastPass needs to “see” the website in order to capture the exact username and password fields, as they differ from website to website. When you visit the website for the first time after importing, use the in-field icon to force fill the credentials and log in. It will autofill every time after that.
