You can import your Dashlane passwords (exported as a CSV only) into your LastPass vault.
Restriction: Files that were exported from Dashlane as a DASH file are not supported.
Before you begin: Export your stored data from Dashlane as a CSV file (
instructions here).
- Log in to LastPass and access the Import page by doing either of the following:
Login method |
Instructions |
LastPass browser extension |
- Select
in your web browser toolbar, then enter your email address and master password and click Log In.
- Select
then go to .
LastPass website |
- Go to https://lastpass.com/?ac=1 and enter your email address and master password, then click Log In.
- Select Dashlane.
- Upload your exported Dashlane CSV (by selecting it from your computer or using the drag-and-drop method).
Troubleshooting: If incomplete items are detected (entries are missing a username, password, and/or URL), select
(under the Data Status column), then enter the missing information and select Save.
- By default, all items are selected for import. If desired, make the following changes:
- De-select items you don't want to import.
- If you want to create duplicate items (by importing items with the same username, password, and URL that already exist in your vault), enable the Select all duplicates setting at the bottom of the list.
- Select Import All.
You have imported your stored passwords from Dashlane into LastPass.
