You can import all of your Safari passwords (exported as a CSV only) directly into your LastPass vault.
Before you begin: Export your stored data from Safari as a CSV file (
instructions here).
- Log in to LastPass and access the Import page by doing either of the following:
Login method |
Instructions |
LastPass browser extension |
- Select
in your web browser toolbar, then enter your email address and master password and click Log In.
- Select
then go to .
LastPass website |
- Go to https://lastpass.com/?ac=1 and enter your email address and master password, then click Log In.
Your vault displays the Step 1/3. Where are your passwords now? page.
- Select Safari.
Your vault displays the Step 2/3. Export & upload page.
- Under Upload the exported file to LastPass, choose from the following:
- Drag and drop the CSV file exported from Safari.
- Select browse your computer. Browse for the Safari export file on your computer, select it and click Open.
Your vault displays the items found in the Safari export file.
Troubleshooting: If incomplete items are detected (entries are missing a username, password, and/or URL), select
next to the affected item (under the Data Status column), then enter the missing information and select Save.
- By default, all items are selected for import. If desired, make the following changes:
- De-select items you don't want to import.
- If you want to create duplicate items (by importing items with the same username, password, and URL that already exist in your vault), enable the Select all duplicates setting at the bottom of the list.
- Select Import All.
You have imported your stored passwords from Safari into
LastPass.
