Install LastPass software for users in the new Admin Console
    LastPass Business accounts are provided Windows and Mac installation options for local user installation or automated deployment across the organization. Additionally, LastPass admins can limit features, configure parameters, and/or enable logging when deploying the automated silent installer for Windows.
    Remember: LastPass must be installed on each machine in order to be used. If you have a Windows server environment you only need to install LastPass on the servers being used. If instead your organization gives each user their own Windows or Mac operating system, then the software will need to be installed on each machine.
    Attention: The Firefox extension is no longer included in the installer due to disabling Sideloading. View additional information here or learn more from Firefox.
    Note: Are you seeing something different? See instructions for the previous experience in the legacy (old) Admin Console.
