Install LastPass Universal Proxy v4.x
In order to use LastPass Universal Proxy you need to download the LastPass Universal Proxy software, then install it on a server within your infrastructure, using a Windows Installer.
Before you begin:
Install Amazon Corretto version 8 JDK/JRE 64-bit or version 17 JDK/JRE 64-bit to your environment.
About this task:
What to do next:
Configure the LastPass Universal Proxy settings using either the command line interface (CLI) or the server.properties configuration file.
