How do I integrate Duo Security with my LastPass Business account?
LastPass Business supports Duo Security integration, which allows admins to configure policies and authentication methods when using Duo Security.
For more information about all Duo Security offers for LastPass, see the LastPass & Duo Security Overview.
Prerequisites for setup
Before you start, ensure you have the following in place:
- Duo Security account
You can create a Duo account (be sure to select LastPass as your integration type during account creation)
- LastPass Business account
Step #1: Set up the LastPass application in Duo Security
You can set Duo Security as a multifactor authentication option for your users, which they can then use as their second factor of authentication when logging in to LastPass. For this, you must first set up LastPass in Duo Security.
Step #2: Set up the Duo Security integration in LastPass Business
In order to set Duo Security as a multifactor authentication option for your users, after having configured LastPass in Duo Security, you are required to set up Duo Security integration in LastPass Business itself.
Step #3: Enable Duo Security as a multifactor option
Before your users can set up Duo Security at their end as an added layer of security to protect their LastPass account, you need to enable Duo Security as a multifactor authentication option in LastPass Business.
- From within the Admin Console, go to .
- Under Enabled Multifactor Options, toggle on the switch for the Duo Security option.
Step #4: Add and configure Multifactor Authentication policies for Duo Security
You can refine the details of Duo Security integration by configuring a number of policies related to Duo Security specifically.
- From within the Admin Console, go to Settings > Policies in the navigation pane.
- Click Add Policy, then choose from the following policies:
- Under Multifactor, select Require use of Duo Security.
- To require Duo Security to be used X amount of days after the user account is created, enter a number in the Value field (optional).
- Enter the Duo Security integration key, secret key, and API hostnames in the respective fields.
- Select your desired user list for which this policy should be applied.
- Enter Notes for additional information about this policy (optional).
- Under Multifactor, select Require use of any multifactor option.
- Under Multifactor, select Use username portion of email address as Duo Security username.
- Under Multifactor, select Use Duo Web SDK when possible.
- Click Save when finished.
Step #5: Advise your users to set up Multifactor Authentication
Once you have completed the steps above, your users can set up and enable Multifactor Authentication for their LastPass Business account.
Important note about the removal of users enabled with Duo Security
Duo Security integration keys are associated with your LastPass Business account. If you remove users from your company account without first disabling Duo Security as their multifactor authentication option, those users may become locked out of their LastPass account (if it is converted to a LastPass Free account) once removed.
For this reason, we recommend disabling Duo Security for users you plan to remove, as follows:
