Integrate RSA SecurID with my LastPass Business account
LastPass Business supports RSA SecurID integration, which allows your users to utilize RSA SecurID as their second factor of authentication when they log in to LastPass.
Limitations and compatibility
RSA Authentication Manager Features | Supported in LastPass Business? |
RSA SecurID Authentication via Native RSA SecurID UDP Protocol | No |
RSA SecurID Authentication via Native RSA SecurID TCP Protocol | No |
RSA SecurID Authentication via RADIUS Protocol | Yes |
RSA SecurID Authentication via IPv6 | No |
On-Demand Authentication via Native SecurID UDP Protocol | No |
On-Demand Authentication via Native SecurID TCP Protocol | No |
Risk-Based Authentication | No |
RSA Authentication Manager Replica Support | Yes |
Secondary RADIUS Server Support | Yes |
RSA SecurID Software Token Automation | No |
RSA SecurID SD800 Token Automation | No |
RSA SecurID Protection of Administrative Interface | No |
Prerequisites for setup
Before you start, ensure you have the following in place:
- RSA SecurID account
- LastPass Business account
Step #1: Set up a RADIUS client and obtain RSA SecurID integration info
LastPass Business supports RSA SecurID authentication via RADIUS, enabling you to set RSA SecurID as a multifactor authentication option for your users. For this, you must first set up a RADIUS client in your RSA Authentication Manager and obtain some RSA SecurID information.
Step #2: Set up RSA SecurID via RADIUS integration in LastPass Business
In order to set RSA SecurID as a multifactor authentication option for your users, after having set up a RADIUS client, you are required to set up RSA SecurID integration in LastPass Business itself.
Step #3: Enable RSA SecurID as a multifactor option
Before your users can set up RSA SecurID at their end as an added layer of security to protect their LastPass account, you need to enable RSA SecurID as a multifactor authentication option in LastPass Business.
- From within the Admin Console, go to .
- Under Enabled Multifactor Options, toggle on the switch for the RSA SecurID/RADIUS option.
Step #4: Add and configure a Multifactor Authentication policy
With LastPass Business, you can leave the multifactor authentication decision up to your end users, or you can mandate its use with our configurable security policies. Add a policy to require your users to use a multifactor authentication solution.
- In the new Admin Console, go to .
- Under the Password multifactor policy category, select Require use of any MFA option.
- Select your desired user list for which this policy should be applied.
- Optional: In the Settings field, enter notes for additional information about this policy.
- Select Enabled in the Status field.
- Select Save changes when finished.
Step #5: Advise your users to set up RSA SecurID Multifactor Authentication
Once you have completed the steps above, your users can set up and enable RSA SecurID Multifactor Authentication for their LastPass Business account.
