How do I integrate SecureAuth with my LastPass Business account?
Required for setup
- SecureAuth account
- LastPass Business account
Step #1: Get the SecureAuth authentication API application credentials
Step #2: Set up the SecureAuth integration in LastPass Business
- Go to .
- Enter the Application ID, Application Key, and Realm that you copied from Step #1.
- Click Update when finished.
Step #3: Enable SecureAuth as a multifactor option
- From within the Admin Console, go to .
- Under Enabled Multifactor Options, toggle on the switch for the SecureAuth option.
Step #4: Add and configure a Multifactor Authentication policy
- From within the Admin Console, go to in the left navigation.
- Under Multifactor, select Require use of any MFA option.
- Select your desired user list for which this policy should be applied.
- Enter notes for additional information about this policy (optional).
- Click Save changes when finished.
Step #5: Advise your users to set up Multifactor Authentication
Once you have completed the steps above, your users can set up and enable Multifactor Authentication for their LastPass Business account.
About the removal of users enabled with SecureAuth
The SecureAuth integration is associated with your LastPass Business account. If you remove users from your company account without first disabling SecureAuth as their multifactor authentication option, then – once removed – those users may become locked out of their LastPass account (if their account is converted to a LastPass Free account). For this reason, we recommend disabling SecureAuth for users you plan to remove.
