Integrate Symantec VIP with my LastPass Business account
LastPass Business supports Symantec VIP authentication. In order to set up this integration, you must provide LastPass with a Symantec VIP certificate.
Required for setup
- Symantec VIP account
- LastPass Business account
Step #1: Download the Symantec VIP certificate for LastPass
Follow the instructions to request a Symantec VIP certificate and download it in PEM format.
Step #2: Set up the Symantec VIP integration in LastPass Business
Step #3: Enable Symantec VIP as a Multifactor Option
- From within the Admin Console, go to .
- Under Enabled Multifactor Options, toggle on the switch for the Symantec VIP option.
Step #4: Add and configure a Multifactor Authentication policy
- In the new Admin Console, go to .
- Under the Password multifactor policy category, select Require use of any MFA option.
- Select your desired user list for which this policy should be applied.
- Optional: In the Settings field, enter notes for additional information about this policy.
- Select Enabled in the Status field.
- Select Save changes when finished.
Step #5: Advise your users to set up Multifactor Authentication
Once you have completed the steps above, your users can set up and enable Multifactor Authentication for their LastPass Business account.
About the removal of users enabled with Symantec VIP
The Symantec VIP integration is associated with your LastPass Business account. If you remove users from your company account without first disabling Symantec VIP as their multifactor authentication option, then – once removed – those users may become locked out of their LastPass account (if their account is converted to a LastPass Free account). For this reason, we recommend disabling the Symantec VIP for users you plan to remove.
