How do I log in to LastPass using a temporary one-time password?
Access your LastPass online web vault by logging in with a one-time use password on the specific One-time Passwords login page.
- Navigate to the One-time Passwords login page at https://lastpass.com/otp.php.
- Enter your LastPass account email address and a one-time password that you generated.
- Click Log In.
You are now logged in to your online web vault for LastPass.
What to do next: It is recommended that you cross the one-time password you used off your list (if printed or stored elsewhere) and/or generate a new one-time password for future use.
