How do I log in to LastPass using different multifactor authentication options?
LastPass allows you to set up and configure more than one multifactor authentication option so that you can access your LastPass vault by authenticating from any device where you have set up and registered authenticators.
Use an alternative multifactor option from the desktop
Before you begin: You must have more than one multifactor authentication option enabled within the Multifactor Options of your LastPass vault before proceeding.
You can log in to LastPass using the
LastPass browser extension or via your online web vault login page and choosing an alternative multifactor authentication option in order to access your vault.
You have now logged in to LastPass and authenticated using a different multifactor option than your account's default selection.
Use an alternative multifactor option from your mobile device
You have now logged in to the LastPass Password Manager mobile app and authenticated using a different multifactor option than your account's default selection.
