How do I log in to Windows using LastPass Workstation Login?
Once you have completed the setup of LastPass Workstation Login for Windows, you can use the LastPass Authenticator's stored biometrics or PIN Code to log in to your Windows workstation – no password required!
Alternatively, you can log in using a One-Time Passcode, which is generated within the LastPass Authenticator on your registered device (if policies permit you to do so), or you can log in as usual with your username and password for your Windows account.
Please note that if you change your Windows user account password, you will be required to log in with your Windows username and password to authenticate at least once before you are able to log in using the LastPass Authenticator again.
Log in using an authentication request
Your mobile device must be online (connected to the Internet) in order to use this login method.
- On your mobile device, open the LastPass Authenticator.
- On your workstation, click to select LastPass as your sign-in option.
- Your Windows username is pre-populated for you – proceed to log in to Windows.
- On your mobile device, tap or select Accept when prompted.
- Verify your identity using stored biometrics (face recognition or fingerprint identification) or PIN Code on the app.
Log in using a One-Time Passcode (OTP)
You can log in to your Windows workstation using a One-Time Passcode generated from the LastPass Authenticator, which is a login method that can be used if your computer is online or offline.
- Check the box for the Log in with password or One Time Password option.
- Locate the One-Time Passcode displayed for your Windows workstation.
- Back on your workstation, enter your One-Time Passcode into the field and proceed to log in.
