Manage access restriction for my mobile devices
You can enable or disable the requirement of LastPass sending a verification email containing a secure link that you must click on in order to allow you to access your account from a mobile device.
- Click the Mobile Devices tab.
- Choose one of the following options:
If you want to restrict access only to those devices you verified, click Enable.Tip: If a "Disable" button is displayed, it means that access is already restricted.
- If you do not want to restrict access to verified mobile devices, click Disable.
Tip: If an "Enable" button is displayed, it means that access is already unrestricted.
Results: You have updated your access restriction for mobile devices.
