You can view all LastPass users for your account and their user statuses, and take appropriate action if needed.
- Go to .
- Select your desired user.
- The configuration options will vary depending on the user's account status, as follows:
Reset
master password
If an admin has been set as a Super Admin via "Permit super admins to reset
master passwords" policy, there will be an option for them to change the
master password for that particular user. This change will be immediate and the Admin will instantly be prompted to create a new
master password for the user's account.
Learn more.
Users Awaiting Approval
For accounts that provision users via the LastPass Active Directory Connector and have configured it to add users as pending rather than automatically active. Select
Reject or
Approve to change the user's status.
Require
master password change
This will force the user to manually reset their
master password. They will receive the notification to do this the next time the user logs in.
Learn more.
Destroy all sessions
This will log the user out of all active sessions across all devices.
Disable user
Temporarily disable the user’s account making it inaccessible to them but not deleting the account entirely. Please note that disabled user accounts are retained for the lifetime of the account.
Delete user
You should weigh the decision carefully about using this option versus the "Remove User from Company" option. Deleting a user will delete that user’s LastPass account entirely. If the user has saved any personal logins or other data to their vault then they will no longer have access to that data.
Remove user from company
This option will remove the user from your LastPass account, and will delete all shared folders from the user’s account. With this option, the user will continue to have access to their account as a standard LastPass user.
Learn more.
Disable Multifactor
This will disable all Multifactor Authentication services for the user’s account. If the policy “Prohibit multifactor disable via email” is enabled, this option will be the only way for Multifactor Authentication to be disabled.
Edit name
Assign a nickname to the account that may be more recognizable to you than the user’s email address.
Reinvite user
Send another invitation for the user to activate their account.
Activate user
Change the user's account status to Active.
