Manage OAuth Keys for users in the new Admin Console
    Create and manage OAuth Keys in the LastPass new Admin Console for setting up directory integrations between LastPass and your Service Provider as a means to authenticate LastPass users.
    About this task: To create a new OAuth key, do the following:
    3. Go to Advanced > Keys.
    4. Under OAuth, click Add key to create a new OAuth key.
    5. Your new OAuth Key contains the following fields and actions for each:
      Setting in LastPass Instructions
      Client ID
      • Click to view
      • Click to copy
      Client Secret
      • Click to view
      • Click to copy
      Callback URL Enter the Callback URL for your desired Service Provider, then click Save
      OAuth Key If desired, click to delete this OAuth key if it is no longer needed
      Warning: Deleting an OAuth Key will invalidate any integration you have set up with a Service Provider that is currently using this OAuth Key.
    Results: You have created, edited, or deleted an OAuth Key for LastPass.
