Manage devices using passwordless login
You can view your passwordless login devices for accessing your vault and delete them if needed.
Attention: Using passwordless login for your vault requires LastPass browser extension version 4.96 or later.
Before you begin: You must have
enabled passwordless login for your vault and logged in to LastPass from at least one device.
Results: You have deleted your desired
passwordless login device(s) and will now be required to enter your
master password when you log in to LastPass from those devices.
