Manage strict equivalent subdomains
If you have a single account shared across multiple subdomains, you can use LastPass to set those sites up as equivalent subdomains so that you don't have independent site entries for each stored in your vault.
Add a new equivalent subdomain
For equivalent subdomains (meaning you have the same login credentials for Site #1: https://subdomain.example.com and Site #2: https://sample.com), if you want to be more granular about which fill options appear on specific URLs, then you would add your equivalent subdomain as: =subdomain.example.com , sample.com in your entry.
- Both domains and subdomains can be entered by a LastPass user (e.g., sample.com and services.sample.com, respectively)
- All subdomains and paths are considered equivalent automatically by default (e.g., services.sample.com where "services" is the subdomain)
- To mark subdomains as having the same login credentials in LastPass, specific syntax is required. You must enter "=" directly before the subdomain, then enter a space after the domain, then enter a comma, then enter another space (e.g., =services.sample.com , login.lastpass.com)
- Top-level domains (TLDs) are not accepted and will be considered as invalid (e.g., *.com)
- Click the Equivalent Domains tab.
- If you are unable to locate any of your desired domains in this list, click Add.
- Enter a list of subdomains you wish to use with the same login credentials using the syntax described above (example: =services.logmein.com , login.lastpass.com).
- Click Add when finished. If you encounter a message that your entry is not considered equivalent, please see Why doesn't LastPass recognize my equivalent domain as a valid domain?
- If prompted, enter your master password, then click Submit.
- When prompted, click OK to confirm.
Edit an existing equivalent subdomain
Delete a set of subdomains
- Click the Delete icon
from the "Equivalent Domains" section.
