Manually add users in the new Admin Console
Manually add users and admins to your LastPass Business account (trial or paid) by adding them individually or by using a bulk list. You can also upload a batch list of users using a CSV file.
Note: Alternatively, you can view legacy instructions for the Password Manager Admin Console or the SSO & MFA Admin Console.
About this task:
When adding users to your account, the system will determine whether or not the invited user already has an existing
LastPass Business account based on their email address. The user will experience one of the following:
- Brand new users will receive an activation email to create an account.
- Existing users can choose from the following options:
- Join your LastPass account using the same email address associated with their existing account
- Create a new LastPass account for company use only
Note: There is no limitation for the amount of users you can add to your LastPass account.
Results: You have successfully added your users manually.
