How do I manually sync my LastPass account data?
If you recently added or updated data stored in your account but do not yet see the changes in your LastPass vault, you can manually force a sync using the LastPass web browser extension.
- Click the LastPass icon
in your browser toolbar.
- Select Account Options OR < your username > at the bottom of the menu.
- Select to force a sync of your vault data.
Troubleshooting:
If your vault syncing issues are not resolved, you can clear your local cache for your active session by doing one of the following:- Click the active LastPass icon
in your toolbar.
- Go to .
- Log out of LastPass, then log back in to access your vault and confirm that your data has synced.
