How do I migrate from using AD FS or PingFederate to a cloud-based federated login identity provider for LastPass?
    If you have set up your LastPass Business account to provision users with federated login via AD FS or PingFederate and want to migrate to a cloud-based Identity Provider federated login solution (Azure AD, Okta, Google Workspace, or PingOne) for LastPass, you can do so by defederating your users, uninstalling the LastPass AD Connector and LastPass Custom Attribute Store, then enabling federated login for your desired cloud-based solution.
    Before you begin:
    WARNING! All users must be defederated BEFORE you remove the LastPass Custom Attribute Store (AD FS plugin) and Active Directory Connector, otherwise the K1 attribute will not be accessible, making the master key irretrievable.
    Limitations and compatibility:
    • Do not run the AD FS or PingFederate and cloud-based configurations concurrently to manage the same users.
    • There is currently no ability to take a mass action to defederate user accounts, this will need to be done manually for each user.
    • It is good practice to make a list of all users and their federated login status before beginning the process. This will help to ensure no one is left behind. Learn how to generate a report of your users.
    • After your users are defederated, user accounts will have a known master password. Once you set up cloud-based federated login, user accounts will need to log in with their known master password to complete the conversion to federated status.
    • Converting an account does not disable any multifactor authentication options that have been set up with the Identity Provider (Azure AD, Google Workspace, Okta, or PingOne).
    Step #1: Defederate your users
    About this task:
    You can change your users' account status to defederated by resetting their master password(if your admin account is enabled with the "Permit super admins to reset master passwords" policy) by doing the following:
    1. Go to https://admin.lastpass.com/ and log in to access the new Admin Console.
    2. Go to Users > Users.
    3. Select your desired federated user.
    4. Click Reset master password.
    5. Enter your own master password, then click Submit.
    6. Enter a new master password for your user and confirm it.
    7. By default, the Force password change on next login option is enabled. We recommend keeping this option enabled so your user will be prompted to set their own master password upon their next login.
    8. Click Submit.
    Results: Your user's account status has now changed from federated to defederated, as indicated by the missing asterisk next to their name in the User list.
    Step #2: Uninstall the LastPass AD Connector and LastPass Attribute Store
    About this task:
    1. Uninstall the LastPass AD Connector.
    2. Uninstall the LastPass Custom Attribute Store.
    Step #3: Set up federated login using a cloud-based identity provider
    Follow the instructions to set up federated login for a supported cloud-based identity provider from the list below.
    Restriction: LastPass does not support the use of multiple domains for directory integrations and federated login, including the use of different directory instances and/or multi-domain & multi-forest configurations. Learn more about federated login limitations.
