How do I move a sub-folder up a level in my vault?
    If you want to move a sub-folder back up to the top level, you can do so by using the renaming feature in your LastPass vault.
    About this task:
    To move a sub-folder up a level, do the following:
    2. Right-click on the name of a folder, then select Rename Folder.
    3. Uncheck the option, Add as a subfolder here.
    4. Click Save.
    Results: The folder has moved to the top level in your vault.
