If you have set up identities in your LastPass vault, you can export your stored data for all identities, or for each individual identity.
and select Open My Vault.
- In the main toolbar at the top of the page, use the user account drop-down menu then use the sub-menu to select your desired individual vault identity, or select All for all identities.
- If prompted, enter your master password. If desired, select Do not re-prompt for and use the drop-down menu to select a time interval.
- In the left navigation of your vault, go to .
- When prompted, enter your master password and select Continue.
Result: A CSV file containing your data is downloaded.
You have successfully exported your LastPass identity data in CSV format.
