Export Wi-Fi passwords from LastPass
    LastPass has the ability to export Wi-Fi passwords stored as LastPass secure notes to your computer (Windows only).
    Note:  In order to use this functionality on Windows, you must allow Windows to manage your Wi-Fi connections. Third party Wi-Fi connection managers such as the one provided by your Wi-Fi adapter’s manufacturer (for example, Intel, etc.) are not supported.
    Requirements for exporting
    In order to import and export Wi-Fi passwords, your Windows machine must have a Wi-Fi adapter installed, which you can determine by following these instructions.
    If you would like to import and export Wi-Fi passwords from the LastPass web browser extension, you will need the following:
    • The ability to run the LastPass Universal Installer (requires admin privileges) to ensure that the LastPass Wi-Fi utility is installed
    • The LastPass browser extension that includes the binary component (also included in the Universal Installer – learn more).
    View the "Related Articles" below for instructions.
