You can export the contents of your LastPass vault as a CSV file so that you can keep a secure copy for your own records.
Important: These steps can only be performed using the LastPass browser extension.
- Click the LastPass icon
in your browser toolbar.
- Select Account Options OR < your username > at the bottom of the menu.
- Go to .
- If prompted, enter your master password. If desired, select Do not re-prompt for and use the drop-down menu to select a time interval.
- Select Continue.
Result: A CSV file containing your data is downloaded.
You have successfully exported your LastPass vault data in CSV format.
Important: If you decide to make changes to the exported CSV file, you must use lowercase text for all column headers.
If a CSV file is not generated and instead you encounter a message that an email notification was sent for verification, please view instructions that apply to you:
