How do I prevent LastPass from filling erroneous form fields?
If you are on a specific site and there is a field on that page that LastPass is filling with an incorrect value but you want it to be filled with a different value (e.g., filling "abc123" but needing to be filled with "abc456"), you can edit the item.
About this task:
To prevent LastPass from filling in the incorrect value, follow these steps:
- Locate the site in your LastPass vault that contains the incorrect data (e.g., "abc123").
- For each matching site, click the Edit icon
- Update the erroneous value.
- Click Save when finished.
