How do I prevent the in-field icon from appearing for specific items?
If you do not want the gray in-field autofill LastPass icon to appear in your login fields, you can disable it within your LastPass browser extension Preferences to remove it for all sites, or add a site as a Never URL so that the icon does not appear for specific sites.
