You can regenerate a key for the Microsoft Authenticator in order to set it up for your LastPass account again if you lost your mobile device or are concerned that the security of your existing key may have been compromised.
Important: This will require you to re-associate the Microsoft Authenticator with your LastPass account, then re-enable the Microsoft Authenticator from the Multifactor Options in your LastPass Account Settings.
and select Open My Vault.
- Select the Multifactor Options tab.
- Click the Edit icon
for Microsoft Authenticator.
- For the "Regenerate Key" option, click Regenerate.
- Enter your master password, then click Continue.
Result: Microsoft Authenticator is now disabled for your LastPass account.
- When prompted, click OK.
You have disabled the Microsoft Authenticator as your Multifactor Option in Account Settings.
What to do next: You can re-associate Microsoft Authenticator with your account, then re-enable Microsoft Authenticator in your Multifactor Options.
