Remove MFA Apps for LastPass users
    LastPass admins can remove individual MFA Apps from within the new Admin Console.
    3. Go to Applications > MFA Apps.
    4. Select your desired MFA App (workstation, Azure AD, AD FS, etc.).
    5. Click the More Options icon then select Remove app.
      Remove MFA App in Admin Console
    Results: You have successfully removed your selected MFA App.
