How do I reset my Enterprise API provisioning hash?
    You can reset your existing provisioning hash for the Enterprise API in the LastPass Admin Console, which will invalidate the previous hash everywhere it is used.
    3. Go to Advanced > Enterprise API.
    4. Select Reset your provisioning hash.
      Warning: Please note that if you have already established a provisioning hash for the Enterprise API, then selecting Reset your provisioning hash will invalidate the previous token, and will require you to update your established Enterprise APIs with the new hash.
      Reset your provisioning hash for the LastPass Enterprise API
      Troubleshooting: If you do not see the Reset your provisioning hash setting, you will need to reset your API key in the LastPass AD Connector settings. View these instructions instead.
    5. When ready, click OK to proceed.
    Results: You have generated a new provisioning hash for your Enterprise API integrations.
    What to do next: You must update your API clients with the new provisioning hash.
