How do I reset my master password using a hint/reminder?
If you previously set up a master password hint/reminder (either during account creation, when you last changed your master password, or by manually entering one into your Account Settings), you can have LastPass send you a clue in a reminder email.
- Log out of LastPass on every trusted computer and/or mobile device where you have installed LastPass and accessed your LastPass vault. You can check your active sessions for all devices.
- Log back in with your new master password.
Clear the browser cache on all web browsers where you accessed LastPass in order to clear the Recovery One Time Password that was created from accessing the LastPass website.
Generate new temporary, one-time passwords because all OTPs you generated previously are now invalidated and no longer listed due to your vault being re-encrypted from your master password change.
