How do I resolve autofill issues for LastPass on my Huawei mobile device?
If you are encountering autofill issues when using the LastPass app for Android on a Huawei mobile device, you can adjust your device's battery management settings to prevent power saving on the mobile app.
Your device will no longer close the LastPass app to preserve battery power, allowing autofill to work persistently.
