How do I run the Security Challenge for LastPass on my mobile device?
It can be overwhelming when you're trying to start improving your online security. LastPass can help by evaluating everything you've stored in your vault, checking for weak, duplicate, or compromised passwords. To do so, run the Security Challenge in the LastPass Password Manager mobile app, and learn about what each of these scores mean.
How can I improve my security score?
It is recommended that you take all of the following steps to increase your overall security for your LastPass vault:
- Eliminate duplicate passwords – View your detailed results, then visit each site that is listed with the same password in use and change the password to something long, unique, and complex. We recommend using the Generate Password feature.
- Eliminate weak passwords – View your detailed results, then visit each site that is listed as having a weak password in use and change the password to something long, unique, and complex. We recommend using the Generate Password feature.
- Stop storing passwords insecurely – If you are storing your passwords in any format that is unencrypted (e.g., web browser password manager, email, notepad, Google Docs, etc.), it is recommended that you use the import passwords feature to begin storing them in your LastPass vault.
- Start using a multifactor authentication scheme – Enabling and using multifactor authentication significantly increases the security of your account. Learn how to enable a multifactor authentication option.
- Re-run the LastPass Security Challenge on a routine basis – Keeping good password hygiene is a daily best practice. It is recommended that you re-run the Security Challenge every few weeks to stay on top of secure password storage.
