If you have enabled more than one multifactor authentication option in your LastPass account, you can choose your default method of authenticating in order to access your LastPass vault.
Before you begin: You must have more than one multifactor authentication option enabled within the Multifactor Options of your LastPass Account Settings before proceeding.
and select Open My Vault.
- Click the Multifactor Options tab.
- At the bottom, use the Default Multifactor Option drop-down menu and select your desired default option.
- Click OK to confirm.
Result: You have now selected your default multifactor option, which will be the first option presented when you log in to LastPass and are prompted to authenticate.
