How do I set up a Datto Autotask integration?
LastPass uses the public APIs of Datto Autotask to access data. To have a fully functional integration you need to enable LastPass to get access to these APIs.
Note: This feature is only available in the legacy Admin Console.
Before you begin: The "Billing Service" must already be added to the contract before proceeding with the steps below.
Step #1: Get API access from Autotask
Step #2: Populate the access for LastPass
CAUTION: If you enter the incorrect username and secret multiple times you will lock the API user in Datto. To unlock the user, use Autotask to remove the lock.
What to do next: Import companies from Datto into LastPass as a Managed Company. See
How do I import companies from PSAs? for more information.
