How do I set up biometrics and mobile account recovery on iOS for LastPass?
When using the LastPass app for iOS, you can set up and use Face ID or Touch ID for account recovery in case your master password is ever forgotten.
You must log in to the LastPass app with your email address and master password before you can set up account recovery using biometrics.
Set up Face ID for LastPass
Before you begin: Please be sure you have done the following before proceeding:
To set up Face ID on the
LastPass app for iOS, do the following:
Set up Touch ID in LastPass
To set up Touch ID on the
- Open the LastPass app on your iOS device.
- Enter your username and master password.
- Tap Log In.
- Choose from the following options:
If this: Then do this: You're logging in for the first time - Enable the Use Touch ID setting.
- Select OK to allow Touch ID for LastPass.
- Touch the Home button lightly (don't press) to scan your fingerprint.
- Enable the Use Touch ID for account recovery setting.
You skipped enabling Touch ID previously, and want to enable it now - Select .
- Enable the Account Recovery setting.
You have now enabled Touch ID for account recovery for the
LastPass app for iOS.
