Set Up Federated Login for LastPass Using Azure Active Directory
Federated login for LastPass Business allows users to log in to LastPass using their organization's Active Directory (Azure AD or on-premise Active Directory) without having to create and use a separate master password.
Please review the account requirements and limitations that apply to federated users, then you can begin the setup process between the LastPass Admin Console and the Azure AD portal.
Account and system requirements
Syncing your Azure Active Directory with LastPass requires the following:
- A Premium tier subscription for Microsoft Azure Active Directory
- An active trial or paid LastPass Business account
- An active LastPass Business admin account (required when activating your trial or paid subscription)
Limitations that apply to federated users
- Additionally, linked personal accounts must be verified on every new device that a federated user will use for logging in to access their LastPass vault.
- Step #1: Create a Provisioning Token and Capture the Connection URL in LastPass
- Step #2: Configure the Provisioning App for LastPass in Azure AD
- Step #3: Configure the Login App for LastPass in Azure AD
- Step #4: Configure Federated Login Settings for Azure AD in LastPass
- Step #5: Add Users/Groups to the Provisioning and Login Apps in Azure AD
In this section:
