Set up LastPass Universal Proxy v5.x
In order to use LastPass Universal Proxy v5.x you need to download the LastPass Universal Proxy v5.x software, then install it on a server within your infrastructure and configure the settings.
About this task:
Important: LastPass Universal Proxy V5.x is incompatible with V4.x. If you are not upgraded to the 5.x version, contact customer support.
Before you begin:
- Before setting up LastPass Universal Proxy v5.x, check that your system is prepared with the minimum software requirements for LastPass Universal Proxy.
- Make sure you have Docker Desktop or Docker Engine installed on your infrastructure.
Operating System Installer Windows IInstall Docker Desktop Linux IInstall Docker Engine Mac IInstall Docker Desktop
Important: The "Restrict access by country" policy is not supported by LastPass Universal Proxy. Enabling this policy in the LastPass new Admin Console will lead to authentication issues. To set a location restriction when using LastPass Universal Proxy, enable the following policies:
- Restrict LastPass Authenticator usage by location
- Accept only LastPass Authenticator login requests
