How do I set up LastPass Workstation Login for Mac as an admin?
As a LastPass Business admin, you can download the LastPass Workstation Login silent installer and deploy it to your users' Macs. You can also configure policies for Workstation Login that suit your business needs.
Once deployed, your users must run the installer to set up LastPass Workstation Login on their individual machines. When the installation is complete, they will be able to use the LastPass Authenticator's stored biometrics, PIN Code, or a One-Time Passcode to log in to their workstations, depending on the policies enabled.
Account and system requirements
- An active LastPass Business + Advanced MFA add-on trial or paid account
- A Mac running either of the following macOS versions with a 64-bit processor required:
- macOS Catalina (10.15.2)
- macOS Big Sur (11.2)
- A mobile device with the LastPass Authenticator installed with passwordless login activated – View activation instructions
Step #1: Configure policies for Workstation Login
You can configure policies for your users that involve authentication methods and actions users can do once they have logged in to their workstation.
Step #2: Download the silent installer for Mac
Save the installer for Mac.
Step #3: Deploy or distribute Workstation Login
Once downloaded, choose from the following:
- If your users do not have local admin permissions and you want to install it for them – Deploy the silent installer using your organization's preferred distribution methods. Once installed, provide your users with these instructions for pairing their LastPass account using the LastPass Authenticator.
- If your users have local admin permissions and you want them to install it on their own – Distribute the installer to your users, and provide them with the following instructions:
Step #4: Follow up with your users
Once your users complete the setup process, your users can log in to their Mac – no password required!
To see your end users' passwordless login experience for their workstation, please see How do I log in to my Mac using LastPass Workstation Login?
