How do I switch to another identity?
You can change between identities from within your vault or using the previous experience (v4.103.0 and earlier) of the LastPass browser extension.
Switch identities from within your vault
Results: You have switched to another vault identity.
Note: While you are using an identity, only the passwords, notes, and items associated with this identity are available to you.
Using the LastPass browser extension (previous version)
Tip: While you are using an identity, only the passwords, notes, and items associated with this identity are available to you.
