How do I uninstall LastPass Workstation Login from my Mac?
    You can uninstall Workstation Login as a troubleshooting measure or if you no longer need it on your Mac.
    Restriction: This feature might not be available for your account as this is a legacy feature.
    Note: Instructions may vary depending on the version of Windows you are running on your workstation.
    1. On the Menu Bar, click the Apple icon then select System Preferences.
    2. Click Workstation Login.
    3. Click Uninstall.
    4. Click Continue > Continue > Install.
    5. Authenticate using your macOS user account password or Touch ID (if set up).
    6. When prompted that you will be required to restart your Mac if you continue, click Continue Installation.
    7. Click Restart.
    8. After your Mac has restarted, log in to your macOS user account with your password.
    Results: LastPass Workstation Login has now been uninstalled from your Mac.
