How do I uninstall Workstation MFA for Mac?
You can uninstall Workstation MFA locally as a troubleshooting measure or if you no longer need it on your Mac.
Note: Instructions may vary depending on the version of macOS you are running on your workstation.
- Locate the saved location where you extracted the WorkstationMFAMac.zip file.
- Choose from the following uninstallation methods:
Uninstallation Method Instructions Silent uninstall - Open Terminal.app.
- Enter the following command:
sudo installer -pkg "/Downloads/Uninstaller.pkg -target /
Note: If you extracted the .zip file to a different location than ~/Downloads, then enter that path after "/ instead. - When prompted, enter your Mac admin credentials.
- Close the Terminal.app window when uninstallation is complete.
Manual (GUI) uninstall - Double-click the Uninstaller.pkg to open.
- Click .
- Click Install Software.
- Click Close when uninstallation is complete.
Results: LastPass
Workstation MFA has now been uninstalled from your Mac.
