How do I unpair then re-pair my LastPass account with the LastPass Authenticator?
You can disable the LastPass Authenticator as your multifactor option for your LastPass account, then pair it again to re-enable it (as a troubleshooting step, if needed).
- Unpair the LastPass Authenticator.
- Re-pair the LastPass Authenticator.
You have successfully unpaired then re-paired your LastPass account with the
LastPass Authenticator as your enabled multifactor authentication option.
