How do I use key features of LastPass?
To start using LastPass, add sites and login credentials in your vault so that the next time you log in to a site, LastPass fills the credentials for you. Other than the ability to access sites without having to remember login details, you can also generate secure passwords for your sites, auto-fill web forms with your address or credit card details when making a payment, securely share sensitive information with other LastPass, and so on.
Overview of key features
Feature | How-to resources |
Log in to LastPass The first step in any process is to log in to your account. |
Log in to LastPass via the web, web browser extension, desktop application, or mobile application. |
Set up multifactor authentication Multifactor authentication adds extra security to your LastPass account by requiring a second login step before authorizing access to your vault. |
Add site data in your vault One of the great benefits of LastPass is that it remembers your usernames and passwords. When you visit a site to log in, LastPass fills the credentials for you, no typing required. For this, you first have to add a site password entry (that is, a set of credentials to log in to a website or app, typically containing a username or email address and a password) to your LastPass vault. |
Set up automatic login The next step in setting up your sites so that LastPass fills the credentials for you on login is to enable the Autologin option for those sites in your vault. |
Generate secure passwords As a security best practice, you can generate secure and random passwords for your sites. |
Securely store sensitive information in your vault In addition to site password entries, you can choose to store other (non-password) items in your vault, such as "sticky notes" with attachments, as well as items that can be used to easily fill online web forms (e.g., addresses, payment card or bank account details, and so on). |
Import data from outside LastPass If you are coming to LastPass from another password manager, you may already have spent a considerable amount of time storing your usernames, passwords, and other data within that application, web browser, or extension. To assist with this transition, you have the ability to import your stored data seamlessly into LastPass. |
Securely share sensitive information with other LastPass account holders You can share an item stored in your vault with another LastPass user by using the Sharing Center. If you change your mind after you've shared an item, you always have the ability to revoke access to your shared item. |
Improve your online security by auditing your passwords Identify security weaknesses in your vault by consulting the Security Dashboard. The Security Dashboard displays your security score, this is the rating of how strong your passwords generally are, and indicates the number of at-risk passwords you have in your vault. |
Use LastPass the way you want by setting up your preferences You can get to know all the ins-and-outs of LastPass by configuring your preferences in Account Settings and the LastPass web browser extension. |
Log out of LastPass Logging out of LastPass is as intuitive an action as in any other application. However, some security best practices are worth adopting. |
