View and accept a shared item
View your shared items, items that have been shared with you or accept shared items from others in your LastPass vault.
- Within your LastPass vault, select Sharing Center in the left navigation.
- Take the desired action:
Action in LastPass Instructions View shared items You can select either the Shared with Others or Shared with Me tab to view shared items.
Accept a shared item - Select the Shared with Me tab, and under the "Pending" section, one or more items are listed. Hover over the pending item and click Accept.
- By default, all accepted shared items are stored in the Sharing Center under the Shared with Me tab in the "Accepted" section. If desired, click the Edit icon
and define a specific folder.
Results: You have viewed and/or accepted your shared item.
