How do I view and manage my active LastPass sessions?
You can view all devices and IP addresses where you accessed your LastPass account using the LastPass browser extension or by logging in to your online web Vault. If you happened to leave an account open on another device or are unsure whether you did so, you can view all of your active sessions, and destroy those sessions if needed.
Using the LastPass browser extension
- Click the active LastPass icon
in your web browser toolbar.
- Select Account Options OR < your LastPass email address > at the bottom of the menu.
- Go to .
- Choose from the following options:
- Kill selected sessions – Check the box for each session you'd like remove, then click Kill checked sessions.
- Kill all but current session – To remove all sessions except the one you are actively in, click Kill all but current session.
You have viewed and/or destroyed your desired sessions.
What to do next: For all sessions that you have ended, you will be prompted to log in to LastPass again to access your account from that device and/or web browser.
Using the online web vault
- Navigate to https://lastpass.com/?ac=1.
- On the General tab, click Show Advanced Settings.
- In the "Tools" section, click Destroy Sessions.
