View changes in item history
    You can review changes made to your items by viewing the item history.
    Note:  The item history only shows a record of the last 5 changes made to each item.
    1. When you edit your item, select .
    2. Select Show.
      Item history pane
    Results: You have viewed the item as it had appeared prior to the last saved changes.
