View SAML response reports in the new Admin Console
View all SAML (Single sign-on) events from users, including time, user, application used, and IP address. Filter by using the Search field, or use the drop-down menu for Time.
Attention: At this time you can only view the SAML response information, you cannot export the report.
About this task:
Within the column in the far-right, click Response to view detailed SAML response info, and click Copy to clipboard if desired.
